OME 2" Lift - Bilstein's Ok?
CO
Visit site
Potentially looking to add an OME 2" spring lift to a basically stock 80. It currently has almost-new yellow Bilstein shocks installed.
Are these yellow Bilstein's Ok for the OME 2" lift?
Or do I need to buy the OME shocks as well?
Kansas
Visit site
If you do upgrade I would recommend getting something better than the OME shocks. I have them on my 97 and they suck. I never really thought much about shocks before but it makes me want something better like a FOX.
UnderDawg
Wannabe welder
Visit site
I just ordered the Fox's 2.0 on flea bay a few days ago. $230 shipped for a pair. Get the 3"-4" lift shocks, then you'll never need to worry about bottoming out and if you go higher your still covered.
SacTown!
Visit site
It will work and you will not bottom out the shocks, but because the shock is shorter you won't get full droop/flex.
If you install 4 inch shocks then you will have to extend your brake lines and extend your bumpstops or you will bottom out your longer shocks.
