Older Dizzy with Newer Coil ?'s
So I attempted to install an early small cap vac advance distributor in my '75, and I'm not getting any fire
I tried all the normal things to see if my coil was shot/ignition switch was screwy, everything seemed fine.
so I chucked the old dist back in, and it started up great
does some or all of the ignitor assy. need to be bypassed to make this distributor work in my vehicle?
thanks in advance
If it's an early small cap, I don't think you want to use the ignitor. IIRC, you would just run the coil and a ballast resistor and condenser. Hopefully someone will chime in with exactly how to connect it. If you get rid of the points and go with an electronic ignition (pertroix, etc),you won't need the ballast or condenser.
Bypass EVERYTHING! Perttronix red wire to coil +, black wire to coil-
Keep in mind that there are TWO black/yellow [coil hot] wires on your vintage of wiring harness. A circuit tester will tell you which is the true 'hot' lead in the harness. The other is called an 'exciter' wire and brings extra juice to the coil during start position only.
Hth
Mark A.
It would depend on what type of distributor you are swapping and what kind of ignitor you have. If both distributors are points type, then they should swap directly, no problem. A points type distributor probably won't work with an electronic type ignitor.
no pertronix
the old one was vac retard w/points, larger clip type cap. the coil looked like this:
the rebuilt one is vac advance w/points small cap
Points is points. It should work assuming that it is OK, the points are set the same and it is timed properly.
All coils look the same.
If you have the ignitor (Part #30) it is a points style ignitor from '76-77.
where to start troubleshooting, then? I checked all the grounds, connections, etc while I had the new one in, but nothing worked until I put the old unit back in, coil tests fine
only thing that I haven't checked is the condensor, I still have a spare from the old unit, are they both going to be the same?
If I recall, the Haynes or the Factory manual details how to bypass the ignitor in case of malfunction. Lemme try and dig that up...
Is there any advantage to the ignitor over the condensor? it sounds like it is an either or thing?
would it be worth my while to remove the condensor and try it that way, rather than disconnecting the ignitor?
thanks for the help so far I'll have to go out in the cold and try a few things, I'll report back
I would have to actually look at my setup, it's been a few years since I did it. It's the Pertronix dealio and I completely bypassed the ignitor, which worked fine at the time. It's only there "for show" now (with a set of points/condensor in the glovebox just in case).
You should be good with the Ignition(+) on the coil(+), and the coil(-) to the dist/condensor. Are your grounds inside the new dist OK?
I think it's just a solid-state version of the same...
Yes. An ignitor is worth having. With an ignitor, there is a low voltage at the points, so there is no arcing and burning and the points last a lot longer.
Hth
Mark A.
mark,
remember, I didn't go with the petronix (I was low on funds, and I've had fine luck with points in the past), the dizzy problem is unsolved, but even with the old dizzy, I dialed in the timing a bit, and it works waaaayyy better than before... it frickin' idles!!! good job on the carb!, and the GR starter makes a load of difference too!
thanks
X2 on the dizzy ground. If the points are not grounding they wont't trigger the igniter properly.
If you have a meter do the following: Set the meter to it's lowest ohms scale. Disconnect the condensor, and with the points OPEN, measure from the negative battery terminal (or any known good ground), to the non movable point contact. You should read zero, or very low ohms. If you don't, then the dizzy body is not grounded properly.
To further test the igniter:With the points still open. Pull the coil wire from the dizzy cap, and attach a spark plug to it. Ground the plug threads. Turn the ignition switch on, and use a clip lead to momentarily ground the movable side of the points. If the plug sparks, you know the igniter is good.
