Read a bit about this in the past, but not sure there is a clear consensus.
So, is there a potential big negative to running one of these engine flush cleaner? The type that you put in and run for 5 minutes just before changing the oil and filter...
Obviously not as smooth and gentle a cleaning as Seafoam etc permanently in the oil, but not that likely it would hurt much either. Conceivably some bigger chunks of crap could be dislodged, but one would think they would likely be caught in the filter soon to be changed...
Seems like that would be a good opportunity to take advantage of an upcoming oil change...
Any more thought on this?
E
E
Why not soak the rusted roof inserts with the stuff.........
out of loop, perhaps.
