OK..queue the theme for "Sanford and Son"
Alpine, Texas
fawkity fawk fawk...this is what i discovered today when i decided to shake out my floor mats. the carpet and pad were soaked on the driver's side. from the looks and smell of it..gag..it must of been going on for quite some time. i think it is probably due to the seals around the doors being old as dirt. i went ahead and ripped out the front carpet and trashed it. i haven't decided if i'm going to replace it or just rip all the carpet out in the entire rig and do some type of spray in liner? not like i'm dying to spend $$$ on replacing the worn out doo doo brown carpet....anyway, if ya look at the middle pic, i accidently ripped up what appears to be some type of insulation board that is glued to the floor. is this just for sound or for thermal/heat protection as well? i was thinking about ripping it all out as it appears water had soaked up between it and the floor based upon the chunk i ripped out. i don't want to rip it out and have my feet on fire when i drive is the reason i ask. sorry of the long ass post.
tia,
pat
Patride,
I'm currently in the same boat full of water.
:D
At this moment have a heat fan running under the drivers side carpet to drive the water out.
There will be heat rising from the cat and muffler on the drivers side so keeping the hard insulation (the chunk) might be a good idea.
I also popped out the black drain plug inside just below the A pillar on both passenger and drivers side until my water problem is under control.
Replaced the windshield gasket two weeks ago and hoping it will seal up real soon.
Cahil
cahilc said:
Patride,
:D
Cahil
cahil
do you think your heat fan will dry it out all the way through the carpet and pad?
the pad soaks up all the water and just holds it there. it was really nasty and the carpet was starting to delaminate and rot. thanks for mentioning about the drain plugs. i am going to pull those. anyone know best place to get the gasket that goes all the way around the door and window? it looks like it is one seamless piece to me....
pat
patride71 said:
cahil
pat
the best place for the gasket will either be your dealer or SOR. Otherwise, wait till someon is parting out their crusier. There have been a lot lately.
I think a few drying fans, a dehumidifer (dessicant is optional) should be OK. Don't forget to apply an antimicrobial agent first. Let me know how the clearance test goes. :D
yeah i set up containment and neg air through one of the back windows.
got the decon chamber set up outside of the driver door. put the antimicrobial down and should be ready for post test after running the air scrubber for 24 hours..... :rolleyes:
isn't property claims humor soooo funny. :rolleyes:
:D
Patride,
Make sure that you check your gutters for cracked sealant - also look for signs of staining on the headliner and on the a-pillars. Sorry about the mess - took me almost 6 months to track down the gutter leak.
Harry
Having been through this myself....
The floor can be lined with the foil that you get from HD. The culprit of your leak is the new window seal. I have a brand new one as well - and the fawker that installed my front window didn't seat it right. I know that the water isn't coming in from the doors even though my seal is questionable because I don't drive the truck in the rain. On the bottom corner of each side of the front glass, the water actually collects - then leaks into the truck from there...
Black RTV went around the window seat this weekend - I'll let you know if it works. Supposed to rain today.
rip all the insulation out...I did a while ago after I dunked my truck in 4ft of water. the insulation just holds water and mold. I dint really feel much of a difference and I drive around bare foot all the time(read:surfer)...
i went through the car wash/drive through high pressure one yesterday.
yeah its def the seal around the windshield.
thanks for the input guys.
hey lowtide, i'm gonna rip out that insulation. it looked like trouble to me too as i could tell water was trapped underneath it. so did you rip the carpet out throughout on yours? also, did you put any type of spray in liner or are you just driving around with bare bones....
WTF are you doing to that poor truck? Sweet Jesus...
As far as drying it out goes, when and if you do the heater thing, be sure to crack your windows a little - the moisture that evaps will need a place to go. If you don't use a portable heater, you can run the truck and put the heater on full-blast for about an hour (cracked windows, of course) - maybe a little longer if it's cold out. That'll dry it out too.
my insulation was soaked like a freakin spunge...me being lazy I pulled the carpet up but not out and reacher my lil girly arm in there and started ripping the s*** out... It helps to play loud fast music( no marley for this kind of s***) because if is wet it kinda gets all over your arms. Then I put some soda cans under the carpet and let the doors open all day and let it dry out....
If ya keep finding this rust ya better start wheeling it...just carry a extra drive shat for the rocks. We cant take these trucks with us when we go...so ya better have some fun now before ya regret it.
hope to start seeing you at the larger TLCA meets......hasta bro. there is still time to register for GSMTR....
well there is no drying the capet and pad because i ripped both out and trashed them.
there is the insulation board (fiberglass?) that is adhered though, which i am getting mixed messages on...not sure if it is or is not needed.
i think i might go nuts and just rip out all the carpet in the whole truck and then come up with a game plan to use a spray in liner of some sort...not sure.
lowtide is right. i need to start wheeling it because i have gone over the edge and there ain't no point in trying to make it pretty. my plan has always been to make it a trail rig once i don't have to to use it as a DD. this might be happening sooner than expected!
Inless that s*** changed from year to year i still have it in my truck and I've tryed to take some of it out....and after trying it I rather wack off with a cheese grater. I'd leave it and wire wheel or brushs the surface rust rattle can it and buy some bed liner at a local joint and bed line it........although you could just try a could coats of semi-gloss rustolem(rolled on)..I used it on the outside of my rig as a two toner job and it has held up well. might be worth a shot and if it doesnt work just bed line it, or dont look down while driving and ya wont notice your crappy floor :)
i was able to pull up a piece of it, accidently, it broke off. 2nd photo on the photos i uploaded on this thread.
i think i can get the rest of it off by just inserting a knife underneath it. i think the glue they put it on with has loosened with the water that got between the insulation board and the floor of the truck. i don't think i'll bother with the passenger side since not much water got in over on that side.
i'll probably go the bedliner route, but seems like that could get messy really fast.
I don't know how hard the bench seat is to get out in the back, but the front seats come out pretty easily, so it might not be too labor intensive. would be taping off a lot of stuff as to not have my dashboard bedlined. :D
it ain't me, its the truck, i promise. :D
i keep "discovering" things as i go along. lots of hidden gremlins, especially in the rust department. i'm just trying to keep it on life support at this point. i don't see myself ever trying to sell this thing, so i might as well rip all the carpet out and bedline it and start trying to get it prepared to be a trail rig....won't be any need for carpet as a trail rig anyway.
