Installed a new oil sending unit yesterday, when the cruiser is on the needle hits up just above the top mark....well the old unit would fluctuate so much I'm not sure if this is normal or if it the unit will "break in" after a few miles...the old unit would read in the middle when running and then drop down to the bottom line at idle when I drove it in the morning, well when I left to head home in the afternoon it would sit below half way and then drop below the lowest mark at idle....and another question is, is the only purpose of the sending unit to tell you what your pile pressure is in the cab? It doesn't effect the movement of the oil in the engine itself, correct?
