I'm assembling my oil pump back on the motor. I can't remember which way the gears goes back in. No, Not the inner gear the outer. There are triangles stamped into the gear. I ASSumed the stamped side goes toward the block?
If I see the pump right, the alignment of the triangles shouldn't matter - the inner gear has 5 lobes on it, while the outer gear has 6 detents. As the gears spin, the triangles will rotate around and lose any 'alignment' you set it too.
Or am I seeing things wrong?
