oil pump cover and gasket
looking for oil pump cover and gasket for 1994 80 series LC. Any ideas on where to get these parts?
Go OEM or don't do it. Only get those parts from a dealer, and do the front main seal while you're in there for sure.
Also plan on using an impact driver with the proper sized bit(#3, Phillips is what I used but I think if you can find the JIS bits, those are an even better fit). I used my little Makita 12V impact driver and had no issues rattling them out. I tried one by hand just for funsies and I couldn't get it to break free and risked stripping it.
what red merle said,i used an impact driver and #3,no problems getting the screws out,gasket was harder to get out than the screws because it was so brittle it broke into little pieces
Why do you need a new cover?
Yup, got a cover of you need it
somehow mine is missing one of the holding screws and one of the hole spaces is broken..... not sure how that happened. Definitely need a new one.... is the part you have new and OEM?
Yes and yes ;)
