Switched from 5W-30 dino oil to Mobil 1. Is the oil pressure supposed to be (or should it be) higher with the synthetic than with the dino?
Is Eugene coastal or inland OR? Unless you have very cold weather there is not reason to run 5w-30
Average temp is 35-40f in the winter, sometimes down in the 20's. Lived there for 3 years. Any of the 40 weight Mobil 1's will work fine.
Did you switch from the same weight oil to the same weight oil? I noticed a pressure difference when I switched from Mobil 1 0W-40 (winter oil) to Rotella 15W-40 (summer oil) and back. I wouldn't think you could discern the difference from the same weight oil between dino and syn though. At least not on the stock gauge...
Oil pressure follows the viscosity of the oil at that particular temperature regardless of weather it is mineral or synthetic,
Thicker oil will give higher oil pressure, better protection to metal (to a point) and will reduce power output and and fuel economy,
Thinner oil is the reverse,
Mobil tends to make their oil thinner than the name would imply, other than that only difference is that synthetic has more thermal stability, it thickens less at colder temperatures and thins less at higher temperatures,
??different filter.
No. Mobil 1 5w-30 is formulated on the light end of the 30 weight scale and lighter than most 30 weight oils, which will lead to your seeing lower oils pressures. I would suggest next time you try one of the 40 weight Mobil 1 oils.
Just remember that it's NOT the oil pressure that "lubricates", it's flow.
Fred
Now why in the world would you want to switch like that between winter and summer ?
Seems you have a mis-understanding of what the numbers mean and how the oil works
Fred
The only way to know what oil to use, in a "used" engine, is with an oil pressure gauge (one that actually reads and displays the pressures as psi).
10 psi/1000 rpm is what to shoot for.
Fred
At idle 4.3 psi or more
At 3,000 rpm 36 – 71 psi
And a what pressure do you think the "squirter's turn off" ?I get what you are trying to say, you could have a plugged oil jet and have oil pressure with no flow and therefore no lubrication of that particular part, but in a healthy maintained 1fz this is unlikely, also if you have little pressure you have little flow, baring a unnatural restriction they are proportional.
also on a 1FZ without pressure you do not have piston cooling, as the piston squirter's turn off with low pressure to conserve oil for other more critical needs,
And what conditions could possibly warrant a change from 0W40 to 15W40 ? Thats just silly.....some people choose an oil based on conditions the engine will operate in, basic maintenance.
Now we already know that 30'ish at 3K rpm works for the 1FZ. Nothing particularly different about that engine.30PSI at 3K rpm may be great for a Ford but would low for a 1FZ.
Fred
Fred
