Note: This feature currently requires accessing the site using the built-in Safari browser.
It is a single wire with a clip that attaches to the top of the sending unit. What rig do you need one for?
That is not the factory connector on your pressure gauge. You will have to put in a T to install and aftermarket gauge as you will have to use the aftermarket sender for the aftermarket gauge. It is very unlikely that an aftermarket gauge would work with the Toyota sender. I don't have what you need.
OK, I'll go slower.
The blue connector on your oil pressure sensor is not OEM Toyota (Toyota didn't use that type of connector). It also does not appear that you have the wire hooked to it either.
In order to add an aftermarket gauge and retain the idiot light you will need to take the Toyota sender out and add a T fitting to the engine. Then you will screw the OEM Toyota sender into the T fitting on one side and the new sensor for the aftermarket oil pressure gauge to the other side of the T fitting.
You cannot just hook an aftermarket gauge to the Toyota sender as the senders have different resistances. It is very unlikely that anything aftermarket would match a Toyota OEM sender.
