Oil Pressure Gauge not so good
All my gauges on my cluster work fine except Oil Pressure. It looks like (but not sure) that sending unit is connected. Any ideas on troubleshooting / process and repair? Thanks
do you mean it doesn't work or the pressure is low?
the sending unit is almost above the oil filter, try to mesure it with a voltmeter
bye
Romer
fatherofdaughterofromer
Moderator
Centennial, Colorado
My oil pressure gauge doesn't work either. The needle isn't even visible. I got another cluster on eBay and I was going to swap out the oil gauge and see what happens.
Website
it's probably the sending unit -- i replaced mine 100K miles ago.
For peace of mind you should probably hook up a mechanical
gage to your block (unscrew the sender and tap in there) and
measure the oil pressure: (1) cold idle, (2) cold 2000 rpm, (3)
hot idle, (4) hot 2000 rpm. Then you can reassemble your
electrical oil pressure sender+gage and confidently know the
correlation between the real pressure and the in-dash gage.
The OEM gage is notoriously flaky but I would not run without
any indicator of oil pressure.
Romer
Moderator
I think the sending unit is usually on the drivers side of the block near the back. I have seen them on the oil filter mount on 78 and later though.
Romer
Moderator
Turns out mine was disconnected at the sender unit. It was loacted next to the Oil filter on the passenger side. The mechanic who told me where to look for it said if it still didn't work, that I could ground the coonection that is suppose to go to the sending unit and if the wiring and the gauge are working, the needle would peg. Fortunatly, it was just disconnected.
