This may seem like a silly question but to do this job does the shaft need to be pulled or is there enough wiggle room to leave it hooked up?
Does this job....This may seem like a silly question but to do this job does the shaft need to be pulled or is there enough wiggle room to leave it hooked up?
I don’t think putting it on ramps is going to do anything for you and I’m not sure the lift helps you either. What you are trying to do is lift the frame up so you can then let the front axle down. Then lifting the motor gets you that last inch or so needed to get the pan out past the cross bar.
Seems like OP just lifted the motor but he also mentions putting it on ramps to make room for the human underneath the truck. I'm wondering how much human room is needed. Might be a game day determination, I suppose.
.Seems like OP just lifted the motor but he also mentions putting it on ramps to make room for the human underneath the truck. I'm wondering how much human room is needed. Might be a game day determination, I suppose.
Did you remove the fan?oil pan
I removed the the sway bar and then two engine mount bolts from underneath. Then jacked up the engine with 2x4 vertical on flywheel about 1-2". Came out!
I'm going with a job so far. Clean up time! Ordered some o-rings from CruiserDan.
Set up where?Riad,
PM me if you have any issues/problems with this project. Plan on a long day! You'll need an inch-lb torque wrench for the smaller 8mm bolts. My old FIPG didn't want to release so I used a ratcheting strap to put constant tension on the oil pan while I worked it loose.
Good luck.
Ali
I don't see why not as it's been done. It'd delete a fair amount of headache and wouldn't be very difficult to create a sleeve, similar to a rollbar dealio that you see on fandangle trophy trucks and such. The forces on that bar is axial and not radial which is easy to handle, i think.
