Oil Leak after wheelin. HELP!!
Arizona
Last week I took my boys out to do a little wheelin. Nothing major, we crossed a 1-2' deep river and played in a few mud holes on the way home. I dont recall hitting anything. But know I have an oil leak.
I know a pic is worth a 1000 words but I'll do my best to expalin. It is on the drivers, side and appears to be coming from where what I think is the front sway bar bolts down. (It is the 1" diameter bar that is infront of the front diff and has a curve to go around the diff cover on the pasenger side.) I have a lot of oil saturating that entire area where the braket is for the sway bar and on the driver's side of my sterring stabalizer. Any ideas?
Second possibility is that before I went last week (about 150 miles ago) I added a quart of Rislone to desludge the engine. I wonder if in doing so I created a leak from a seal. I guess i should steam clean the undercarriage, change out the oil and start from there. (So much for switching to snythetic) This is all new to me so any help would me great.
Thank you!! I know know what a pan hard bar is. Know I need to learn what the pan hard bar is for.
John, your right, I just had time to give it a quick look. If its coming from behind the skid plat wouldn't that lead more towards being caused by adding the Rislone instead of being caused by trail damage?
The "skid plate" that Jon referred to, because it is placed in such a way, collects oil/coolant/PS fluid/etc as residue. When water is pushed over it, the residue gets washed off somewhat, spilling onto your front axle.
That is what MAY have happened.
In a nutshell, you may have already had an oil leak, but was covered up by the plate so it didn't drip onto the driveway or wherever you park.
I don't think this was an intentional design, but I could be wrong.
