Oil/Fuel Filter?
Discussion in '40- & 55-Series Tech' started by Degnol, Nov 11, 2005.
  1. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    27
    Jan 22, 2003
    Kansastitty
    Can you use a remote oil filter, like off of an early 70's F motor as a fuel filter?
    Or should oil filters not be used for gasoline? I'd like the idea of the same filter for both the oil and gas. Plus, mounted vertically with the filter bottom down, wouldn't it also serve as a water trap?
    Just curious.
    Thanks,
    Ed
  2. cruiserbrett
    cruiserbrett Moderator
    2,535
    82
    Feb 19, 2002
    San Diego
    You could use the housing, but I think you should use a filter specific to gas. Napa has tons of fuel filters in the spin on can style and a few look like a ph8a/51515 oil filter interms of size and thread.
  3. Coolerman
    Coolerman SILVER Star
    6,283
    Media:
    2
    Albums:
    1
    1,339
    Jan 5, 2004
    Paint Lick, KY
    You might also check out a marine supply house. My boat has a huge gas/water separator filter.
  4. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    27
    Jan 22, 2003
    Kansastitty
    I think I solved the problem
    Got a remote oil filter mount, drilled and tapped the inlet/outlet for 1/4npt and enlarged the opening for the center of the filter. Carquest had a fuel filter the same size as the oil filter. I'm going to fab a bracket out of 3" angle and bolt it to the frame just before the fuel pump. The filter will "hang" from the bracket to (hopefully) trap any water. I still run a glass filter right before the carb.
    Ed
  5. 65swb45
    65swb45 Elder Statesman Supporting Vendor
    24,353
    9,364
    Apr 14, 2004
    818-953-9230
    Ed, I tend to err on the conservative side when it comes to things that could BLOW UP my truck:eek: so I'd say you should a:pressure test that thing at a safe distance from the rig after you've let the filter seal soak in gas for a week [to test seal compatibility], and b: fabricate some type of shield that would preclude a future leaky seal from letting gas shoot in the direction of the coil, dizzy or battery.
    :frown:
  6. zebrabeefj40
    zebrabeefj40
    3,319
    135
    Feb 19, 2004
    Pepperell MA
    Given that that IS a fuel filter I'd say the seals BETTER be compatable! If it is mounted before the fuel pump why would there be any pressure? What Ed is doing is the same thing most heavy equipment builders, truck builders and, like mentioned already, boat builders have been doing for years. I doubt he'll see any issues with it.
    Nick
