Oil Filters
Dianna
Ohio
I've got a '77 FJ40 with the original F2. What brand filters do you guys use?
Wilton, Ca
I use a Fram PA-8 (I think that is the #) on my F.
-Brian
GSO NC
Dianna,
For oil I'd suggest WIX, purolator, Mobil 1, or NAPA Gold (Which is in fact a WIX filter). Stay away from Fram and Deutch if at all possible.
For air the same. WIX and NAPA GOLD. K&N filters are super for great air flow but are poor at stopping dirt. To take good care of your rings not a good idea.
There are some good studies and tests available for reading online if you do a couple searches.
Hope this helps,
Rice
Gig Harbor WA
Wix, 51515, run em on all my Cruisers.
Lafayette, CO
yup...WIX 51515 or Toyota (the big one).
Wherever the truck stops!!
Website
wirrell.com
I've been using Fleetgard Microfine from the local heavy duty supplier.
Utah
i like those fram with the grip stuff on it..... ok i'm a dork
Poser
Oh...Durka Durka Durka.
Supporting Vendor
MN
[quote author=rusmannx link=board=1;threadid=9456;start=msg82670#msg82670 date=1072901157]
[/quote]
You said it.... :-*
McCall, ID
Big Toyota or the Nippon replacement.
cruiserdan
SupportingVendor Emeritus
Moderator
Land Cruiser Heritage Museum broom closet
15600-41010 or 90915-20004
Naples/Big Pine Key, Fl
[/quote]
Don't feel bad, I also use those and they are easier to deal with.
yooper
a valid location
Chant after me:
OEM....OEM....OEM....OEM....OEM....
15600-41010 is the part number of choice
Fram oil filters are crap. Wix is OK. Napa is Wix.
brian
lebanon,pa
Website
www.facebook.com
i see no reason why fram is crap ???. i ran a hilux to 350,XXX using them, and that was with 4500-5500mls on oil changes.
i use fram on everything i have.
i think that grippy stuff is dumb, but they do it to all their filters so....
part number for a cruiser is PH8A :flipoff2:
[quote author=brian link=board=1;threadid=9456;start=msg82758#msg82758 date=1072907792]
i see no reason why fram is crap ???. i ran a hilux to 350,XXX using them, and that was with 4500-5500k on oil changes.
[/quote]
Same here, used them for years, if there's a legimate reason they suck so bad, what is it? I'll change if there is some research showing poor performance, but I've personally have never had an issue with them.
McCall, ID
That's a very interesting web page. :cheers:
brian
lebanon,pa
Website
www.facebook.com
i'm not puting any faith in that at all.
he seems to have something agianst A/S.
and referring to an oilling diagram for a 2F, the vavle train would be the "cabbose" in the big picture.
i could(even might) be wrong but i don't think any drain back valve is going to prevent the oil from draining off the top end.
and being last in line, the motor would have to be running(or turning over for sometime) before there would enough pressure for the oil to make it to the valves. even more so on a motor that hasn't seen a rebuild in awhile(or ever).
so if you have one of those that fires right away, (mine fires with in... i don't know but it's quick..even when cold ) you're going to be running with no, to little pressure till the oil catchs up with everything. resulting in valve noise.
that's just my thought on things, some assembly may be required.
but too each his own.
brian
lebanon,pa
Website
www.facebook.com
yeah and one more thing.
the flow is from the pump to the filter and then the motor.
so in order for oil to drain backwards it would first have to drain backwards out of the oil pump.
so if the oil drains(by gravity!!) backwards from the pump(re: gear pump) how much oil would that pump be moving?? or more importantly how much pressure would that pump create??
