Oil filter selection
Discussion in '60-Series Wagons' started by zcruiser, Jul 4, 2005.
  1. zcruiser
    zcruiser Needs monitoring
    1,205
    12
    May 7, 2005
    Hillsborough, NC
    Time to start changing all the fluids in my new rig. I've been using Purolator filters in my other vehicles, but came across these filters on eBay:
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7983813019
    [​IMG]
    Anyone with any experience with these filters? Or should I just go to the Toyota parts counter and buy OEM?
    ...and don't say "buy Fram, they're the best!", or I'll know for sure that you're taking advantage of the noob!
  2. 123c
    123c
    134
    Feb 1, 2005
    East Wenatchee, WA
    Those almost look like the cheap filters I bought by my Subaru a few years back. They were made in Thailand, or somewhere like that, they were ok filters, but not the best. Purolators are the best filters out there as far as I am concerned...
  3. 3puttcop
    3puttcop
    332
    1
    Aug 11, 2003
    North Florida
    Filters are not expensive, relatively speaking, changing oil in mornin' and just bought K&N for $11 bucks. K&N has good reputation so I spurged. Fram heavy duty is good also.
  4. 3puttcop
    3puttcop
    332
    1
    Aug 11, 2003
    North Florida
    Also Purolator is good brand but the one for the 2F is very small......I just can't covince myself that that little filter is the best.
  5. hj60
    hj60
    1,511
    5
    Apr 9, 2003
    Ahwatukee, Phoenix, AZ, USA
    If you have CarQuest near you, buy their filters. Same as OEM (Wix). Slightly cheaper.
    If not, go OEM or not at all. If you're committed to changing your own oil, buy by the case. Works out cheaper that way.
    And at some point, Toyota switched to a smaller filter on the 60 2F.
    We use Wix or Racor on our entire fleet (except for the Cats, which use proprietary filters) and have never had an oil-related failure. We even had one truck go 20k miles on one oil change. (Stupid operators.)
    Frams suck. Too large a filtering medium. Doesn't trap enough particulates.
    STPs (what we used before switching to Wix) have a habit of blowing off the engine or bursting.
  6. HZJ60 Guy
    HZJ60 Guy Tank Buster
    2,356
    4
    Sep 11, 2003
    Seattle area
    If you want the best filtration you can buy, get this set up.
    By pass filtration
    I use it on all my vehicles. A normal engine oil filter filters to around 20 microns. An Amsoil bypass filter filters to less than one!
  7. 3puttcop
    3puttcop
    332
    1
    Aug 11, 2003
    North Florida
    that bypass is sweet....What it cost?
  8. zcruiser
    1,205
    12
    May 7, 2005
    Hillsborough, NC
    Bypass setup looks great, especially considering the mounting position of the 3F oil filter. I haven't changed my oil yet, but how the heck do you get that thing off without dumping a quart of oil on the ground???
  9. jesterb
    jesterb
    3,058
    2
    Jun 11, 2004
    Copperhead Rd.
    OEM, Wix, or Mobile 1. I never seem to drip alot when I change it. I'm sure the bypass setup is nice, but you already have aprox. 2 gallons of oil. I think that is plenty IMHO.
  10. CRUISERB1RD
    CRUISERB1RD
    19
    Apr 20, 2005
    If you have the time, punch a hole or two into the filter, let drain overnight, filter comes off bone dry in the morning. For the price, can't go wrong with OEM filters. Also pick up a OEM filter wrench and extra long socket extension to make this a one hand tied behind back job.
  11. nikos8
    nikos8
    469
    Apr 27, 2004
    Connecticut
    There was a test done a while back by someone. Don't remember much about it but I do remember that the Delco scored the highest and Fram the lowest. They had used a large variety of popular filters.
  12. zcruiser
    1,205
    12
    May 7, 2005
    Hillsborough, NC
    Just to make sure I got it straight -- by punching a couple holes in the top of the filter, the oil inside the filter can drain down through the pan? That's just too easy!
  13. swank60
    swank60
    1,484
    244
    Aug 26, 2002
    One of Four Presidential Flying Saucers
    Gotta go ahead and mention the NAPA Gold here, too. Good filter - I've been very pleased with it.
  14. CRUISERB1RD
    CRUISERB1RD
    19
    Apr 20, 2005
    The holes release the pressure. That plus letting it drain overnight does the trick!
  15. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    23,341
    1,369
    Apr 4, 2003
    Panamá
    you have this kit in your HZ engine .. ? withone you use . ?
    I can find some catalog or replacement part in thje amsoil page, to my 2H engine.
  16. silvercrusher
    silvercrusher
    345
    Sep 18, 2004
    vancouver island
    Napa gold is made by Wix.
    Obviously better filtering is optimal.
    As for the 1 micron filtering is that really such a good idea! Unless you are on the ball with maintenance don't even consider it. Oil starvation is hard in on engine and if you don't keep an eye on your delta pressure that 1 micron filter will plug up and you will be screwed. It is great if you are meticulous with maintenance and a very hands on owner but not good for everyone.
  17. HZJ60 Guy
    2,356
    4
    Sep 11, 2003
    Seattle area
    Bypass bypass bypass! That isnt an issue with a bypass filter set up. The oil travels through the normal engine oil filter every 40 seconds or so. Then it takes roughly five minutes to travel through the bypass filter.
  18. 123c
    123c
    134
    Feb 1, 2005
    East Wenatchee, WA
  19. zcruiser
    1,205
    12
    May 7, 2005
    Hillsborough, NC
    Good point, but being fairly meticulous I won't worry about that. Would be interesting to know what my delta pressure is, guess you can hook up identical oil pressure gauges on both sides of the filter and watch difference to monitor its cleanliness? Sounds similar to a system used to monitor air filters on HVAC systems...
  20. silvercrusher
    silvercrusher
    345
    Sep 18, 2004
    vancouver island
    Is there somewhere that i can see actual specs and operation can't seem to find any on the amsoil webpage. So if what you are saying is there are two routes open for the oil to flow to two different size filters how does oil ever go through the bypass. It will always take the path of least resistance. Is there a check valve or directional control valve of some sort?
