oil filter leaking oil 12ht
Malaga Spain
Hi Guys, My oil filter keeps leaking oil. It´s the third oil filter now that i´ve fitted and as usual has started dripping slightly.
Anybody got any ideas. Seem to remember reading about someone having a similar problem, do to with blocked oil pipes or
something. Can anyone help Cheers Adam
do you have the correct filter on there? did you over tighten it? not enough tighten?
Did you clean off the o ring from the old filter?
Have you used the same brand of filter each of the 3x? What brand of filter is it and is it in spec for the oil pressure your motor puts out?
I noticed on my 2H i have to tighten the *@^t out of it because of the oil pressure my motor puts out. I didn't tighten it once as much as i should have. That was an expensive synthetic oil undercoating mess i had.
