Oil Filter Change
Springfield, VA
I am getting ready to do my first oil change on my 1996 LC. I was curious if there are any tips or tricks on replacing the Oil Filter which would minimize the amount of oil dripping on the block and other components. Also, is it best to access and remove the filter from under the vehicle or from up top?
Thanks in advance!
This is something you will get better at the more you do it. My first time on my truck I spilled almost the whole filter, but Monday I hardly spilled any. Just as soon as you get the threads off tilt it up. You can't help but spill some.
I always approach from above. I also then wipe all the old oil from the front axle.
Good luck!
Good luck!
In addition to this...some people place a plastic bag over the filter after you have loosened it.. and backed it off a few threads. Still others, have put a 90 deg. adapter, or a remote filter kit on the vehicle.
If you don't mind reading, do a search...and you will find this discussed. Those with long, skinny, articulating arms do much better at this than some of the rest of us.
The "PHH" and fuel filter replacements, make the oil filter look like child's play.
Cheers.
90 degree adapter :)
Oh, how I want one.
Searching now.
I always shove a couple paper towels against the block right under the filter boss. Catches what little comes out.
If I am feeling particularly neat, I even spread a couple sheets of newspaper over the front axle.
I do the "shove a butt load of paper towels under the filter" trick.
In the stock location, there's no good way of pulling the filter. And the last thing I need is another dirty oily gadget taking up space in my garage.
I put a rag under the filter against the block to catch the oil. Undo the coil wire and the line to the vac canister to give you more room.
I stick a longish piece of cardboard under the filter area and bend it to act as a channel for the oil to flow down. I shove it up under the oil filter and it comes out at the side of the axle and drains to the oil catch pan I have under the vehicle.
I tried that method -- I just must be a tard when it comes to bending cardboard. I couldn't get the bends right, nor position it right to get the oil to hit it right so that it wouldn't go everywhre I didn't want it to go. If I could get it positioned right...I'm sure it would've worked.
After a couple cardboard bending attempts, I gave up...went for the stuff it with lots of paper towels route. :D
