- Thread starter
- #81
And by the way, @*^:<2ha72^# THOSE #3 PHILIP SCREWS!!!!!!!
So with all of this off, how hard is it to get the timing cover off and reseal that as well?
Wow, intense. I think I'm going to spend a few days scrubbing everything clean everywhere. Then when it starts running, I can determine if the seals I replaced fixed it. If not, I can identify the actual leaks and go from there.Do a search for timing cover from @cruiserdan
He is on of the most knowledgeable people here and it took him 28 man hours to remove and replace the timing cover.
This is NOT an easy job unless you are intending on doing the head gasket at the same time, as you have to remove two head bolts to do it.
Also have to remove both oil pans, loosen engine mounts and raise the engine.
All 7 are the same.So the oil pump cover screws... Toyota is out of them here. Went to home depot and they had similar screws there, BUT, the top of the home depot screws are a bit smaller. Thoughts?
Also, the dealership was showing the top 3 were different than the bottom 4 but I see no difference look at all 7???
Not sure if anyone local, and yes I have time, have to wait for the fuel pump which shows up on Friday.All 7 are the same.
Is there anyone local club members you could buy from?
Do you have time to buy from McGeorge?
I would order from McGeorge or Partsouq. Both will be to your door about the same with Partsouq probably being faster. Order more stuff at once (rubber parts in particular) fro Partsouq to offset shipping costs.Not sure if anyone local, and yes I have time, have to wait for the fuel pump which shows up on Friday.
See if you can get these hex screws that come with the wits end kit. This is the kit I used for the job. 80 Series 1FZ Oil Pump Leak Kit - https://absolute-wits-end.com/80-series-1fz-oil-pump-leak-kit/So the oil pump cover screws... Toyota is out of them here. Went to home depot and they had similar screws there, BUT, the top of the home depot screws are a bit smaller. Thoughts?
When I did mine I went to Autozone and "rented" one of theirs. When I called and asked they said they didn't have one that went that high. I had to go in to get some shop towels or something and while waiting at the counter to pay I was looking at their list of rental tools and sure enough they had listed a torque wrench that went to 600ftlb so I pointed it out and asked for it. They had to look it up and get it from another store but I am pretty sure I was the 1st person to use it. It was 3/4"drive, plenty long to get the correct torque and seemed decent build quality. Might be worth giving them a try if you can't find one to borrow. Might ask a diesel mechanic as well as no one I knew that worked on cars had ever used anything that large.Does anyone know someone in the Albuquerque area with a torque wrench for the crank bolt I can borrow?
