Oil Bath air cleaners?
Klamath Basin
This might be a question for LandPimp. Was an oil bath aircleaner ever offered for a 2F? What about another application that might fit the Aisin 2Barrel on my 82FJ60? My machinist recommended one after a head rebuild. I live in an area where a lot of the forest roads are pumice dust, super-fine and abrasive, it gets into everything.
I can't answer the 2F question but I can take pics and measurements of the oil bath I have. I bet you could make it work with minimal effort.
I "think" they were offered as a heavy duty option on some 2F's........let me look tonight.
But you can get a NON US cyclonic air cleaner for a 2F, these are often used fro snorkle installs on US spec 60's. MAF, SOR sells em.
Oil bath from a F might be a problem mounting do to the PS pump and all the emission crap. Prolly the same story with the 2F oil bath if it exists, they were all made for de-smoged motors.
there was an oil bath for 2F, I'll try to post some pics latter. looks alot like the F motor oil bath
Pics and sources would be awesome. The truck is desmogged already, so there is no emissions crap taking up the left fender area. Could this be something I can get at the dealer? (not my local of course, they're idiots) CruiserDan?
To me it looks like you can just replace the element and lid and make a paper filter into an oil bath filter.......
but of course this won't work on a 60, but prolly on 40 with the same kind of cleaner.
doesn't look to much different then the early 40 oil bath on US 40's
John
According to my Oz buds, this is the main reason they all run snorkels is to get the intake up away from the dust.....might consider that, and just think you would be the first in the US to install one for a legitimate reason......
isn't a K&N essentially the same thing?: an oil impregnated air filter?
just curious,
-dogboy- '87 FJ60
not really, an oil bath takes 1 qt of motor oil poured into the bottom of the canister, any dirt in the air swilrs around and falls into the motor oil.
I suppose in a way the KN is kinda sorta like an oil bath.
but whats closer is a dust filter like used on semi trucks(or sold as an Safari snorkle option. this filters the dust out before it gets to the paper filter, then you clean the dust out of the pre--cleaner
just curious,
-dogboy- '87 FJ60
John
Couldn't get link to open. Can you repost the pic of the 2f oil bath?
Hi everyone. Resurrecting a decades old query- "Is oil bath filter useful in mild dusty conditions". I have a modified Toyota 68 FJ40 with 3B and use it as a dump truck. Will appreciate feedback. Thanks
Oil bath filters are easily cleanable and serviceable, but their filtration performance is limited. Paper filters provide superior filtration. If you are in a very dusty ara, a cyclonic air filter housing with a paper filter is probably your best option.
Thanks for the update 👍
