So I stocked up on good Schaeffer's gear oil and went out to change the oil in my tcase and diffs today. When I drained the oil in the tcase, only about 3/4 of a cup came out. I blame myself because I haven't checked the level in several years. But at the same time, there was never enough of a leak to drip, just make it filthy underneath. And none made its way into the transmission because the ATF came out clean when I drained it a couple weeks ago, after about 10 years of use (though I did regularly check the level of the ATF and it was always good). So now, time to get a steam cleaner I can use under the truck (or take it somewhere to be steam cleaned underneath) to clean it up and keep an eye open for anywhere oil might be seeping out.
Luckily I don't think any damage has been done yet, but there was quite a bit of buildup on the magnet on the drain plug.
