rusty_tlc
Dain Bramaged Member
Things change in nine years. I had hair when I posted that.really tough to see on my PC
@AirheadNutMy camping cast iron; a pair of unbranded skillets and a couple of Lodge 10" dutch ovens.
Okay, 6 coats of the FLax oil treatment as prescribed... Baked in on the grill @ 500deg for an our then natural cool down to ambient temp...Scored this 6" treasure at a ReStore store a few weeks ago. In process of seasoning it. . .
has a unique smoothing pattern on the cooking surface, yet is quite smooth...
the only label is a lightly stamped 3A on the bottom
Interested in what you find...Looking for a small/medium sized SQUARE cast iron fry pan.
Reason: easier to carry sideways in kitchen box w/o rolling. Easier to pack around.
There's a certain heating/cooling ritual you need to do when welding cast iron. It needs to cool a lot slower than rolled/solid steel. I think you need some sort of heat sink, like a heated sand pit to dip it in. Not hard, but time consuming.NEXT in line...
I scored a couple casties which need love on my trip to ' the big city'
1st is an 8" fry pan exactly like another I'd rescued...The other score is a round griddle, that's cracked...
here's the recovered and seasoned 8" I use regularly now...
So... seeking opinions and experience on recovery for these...
I've done the de-rusting electrolytic bath for RR plates and spike and could doo same for the 8" fry pan. But what do you all think?
I've given some other castie recovery info which I've seen/read but not yet tried myself (oven cleaner to un season to allow a re-season treatment), but what do you think what should I do for the 8" fry pan? de-rust then re-seaon? It looks smooth so i don't think i want to try and sand the surface, but maybe could with 220 or some good fine stuff...
And the griddle, I'm not sure on that one... it's cracked all the way through, looks epoxied or glued so sketch for sure.... but is there hope?
I've welded a cracked dutchie lid, but that's not as heat-critical as the base of a griddle.... Would addressing the crack via solid steel weld be okay, or would/could it impart a different heat sink making it potentially a bomb? Am I overthinking that?
I could just grind to bevel then bead it up, flap disk it to a good base surface then season it, but something in the back of my head says welding cast iron is ... doable but potentially sketchy...
Dang, didn't see @Live to Ski 's request.Interested in what you find...
[RE: square pan
Quick / dirty of cast iron - pre-heat like a mother, use TR-99 rod in a DC stick welder (IDK of any mig wire in cast) - and then stress relieving via post-heating the surface.NEXT in line...
