OEM wiring harness for towing lights
Ashburn, VA
Sorry for the dumb question but can I assume that our LCs were wired for towing lights?
TIA
Orinda, CA
If you have hitch, your truck is/was probably wired for trailer lights. The light kit from the factory is manually spliced into the harness by the dealer.
I pulled mine out and replaced it with a Hoppy plug & play unit. If you want trailer wiring I highly recommend the Hoppy plug-in play one. It's only ~$40, compared w/ $100+ for the Toyota one.
Ashburn, VA
I do not have a hitch so I guess I do not have the wiring. You have a link for the Hoppy plug and play kit?
cruiserdan
SupportingVendor Emeritus
Moderator
Land Cruiser Heritage Museum broom closet
Hoppy is the way to go. If my original ever takes a dump that is what I will replace it with.
Ashburn, VA
C-Dan,
Off topic question. Is the crush washer for the LC front & rear diff, transfer case and transmission one in the same as the one used in the FJ Cruiser front & rear diff, transfer case and transmission?
If yes, how much?
Thanks
cruiserdan
Moderator
The FJC and the 80 use the same transfer washers, 90430-18008.
The FJC rear diff drain and fill and the FJC front difff fill are the same as the 80 diff drain and fill on both ends, 12157-10010.
The FJC front diff drain is 90430-24003.
90430-18008, $1.07 ea.
12157-10010, $.83 ea
90430-24003, $1.24
