OEM Spring Spacer Thickness?
Does any one know the thickness of an OEM spring spacer?
Will it fix both on the front and rear?
Thanks in advance.
Dixie co. Florida
Item 10 (See picture...)
EDIT: Toyota has a factory spacer since LC's are known for leaning DS...
cruiserdan
SupportingVendor Emeritus
Moderator
Land Cruiser Heritage Museum broom closet
Actually item # 9 in that illustration. #10 is the rubber bushing thingy.
The 80 series spacer is used on the rear only and only on the LH side of early vehicles equipped with a "towing package". The rear springs for said vehicles were the same part number on both sides, requiring the spacer on the left to make up for it. The spacer is steel and is 10mm thick.
D-
