OEM spare tire chain crank
Fort Langley, BC
I swapped some tires around tonight, I've been trying to improve my change times and it's getting pretty fast EXCEPT for swapping the spare tire :banana:
Now I've done the spare tire "lift" mod with spacers so maybe that's part of the problem AND I know it would be easier with a rear tire carrier.... but that crank thing drives me nuts. The hook end keeps falling out. :doh:
I can change each wheel in about 4-5 minutes but the spare is about 15 after I swear and curse. I did notice that little metal loop near the cranking slot was deformed (I thought I've already bent it back once).
Man I hate that thing, drives me nuts. I can barely see in their to get things lined up.
Anybody got any tricks to make this easier?
That's why I got a Kaymar rear bumper w/ tire carrier. It saves the frustration, which is worth the price alone. Like what you're probably doing, I run a 5 tire rotation, and that spare chain crank was a royal PITA. Can you imagine having to change a spare in the middle of the night in the middle of nowhere and have to seat that hook in the slot?
I'm really trying to not do the rear tyre carrier. That's a PITA when you want to open the rear tailgate all the time. There's got to be a way to positively seat that crank.
What about fabbing another positioning guide?
Rich must have an idea?
[quote author=Riley link=board=2;threadid=15779;start=msg150146#msg150146 date=1083650905]
[/quote]
I thought about this several times myself. Some type of funnel type of extension for lack of a better term welded to the mechanism. As long as you are close and just provide a little forward pressure it would pop off.
Use a swing away tire carrier that doesn't impact the use of the tailgate.
Spare under the body = anchor when in mooshy stuff.
You could weld a bar onto the crank mechanism and extend it out to the hole in the bumper. Drimel a square recessed hole in the end of the bar to accept a 3/8" or 1/4" socket adapter, then rachet or air wrench :o the thing down.
:beer:
Rookie2
I like that idea,
simple but effective. only issue being to allow for the angle change. nothing a swivel socket extension wouldnt solve.
Dave
[quote author=Rookie2 link=board=2;threadid=15779;start=msg150326#msg150326 date=1083690957]
:beer:
Rookie2
[/quote]
I like the idea too. But I think it would be easier to use a big piece of threaded rod, then just weld on the appropriate size nut on the end.
hmmm....
I was actually thinking that the odd design would help in preventing spare theft...
E
[quote author=e9999 link=board=2;threadid=15779;start=msg150365#msg150365 date=1083694858]
hmmm....
E
[/quote]
Prevents theft all right. It takes the owner about 20 minutes to get the tire out and back on again. :rolleyes:
I think a lock could solve that problem.
[quote author=moralien link=board=2;threadid=15779;start=msg150340#msg150340 date=1083692311]
[/quote]
Yeh, that would be easier, but if you're going to try and keep the nut slightly inboard of the bumper hole, you'll have to skinny everything down some. The bumper hole is only about 3/4" tall, which gives enough room for 12mm to 14mm socket. That's going to leave a pretty shinny rod.
Wonder if you could use a thicker bar and butt weld an old socket to the end of it with a 3/8" drive facing out? Something like an impact socket without the chrome plating so you don't contaminate the weld. ....plug in the adapter and extension, and you're golden.
:beer:
Rookie2
Or what about a long socket extension that's long enough to have the female end just on the outside of the body (on the bumper) and then drill a hole in the male end and fasten it to the crank receiver with a cross bolt. That way if it didn't work out you could always undo it and go back to the stock method.
Having the 3/8" drive end just barely visable on the bumper would be ok I think.
I know what I'm going to tinker with tonight.
Dave - thanks, I just might take you up on that welding offer. :cheers:
I was thinking swivel socket welded to the trun crank. then cut rod to fit at length and have the female 3/8 drive ride on the aluminum step hole will have to look at it now.
Dave
I think you're both onto it. The axis of rotation of the turn crack would have to be balls-on aligned with the hole in the bumper in order to weld the rod hard to the turn crank. Looking at mine, it doesn't look balls-on. Seems like there needs to be a swivel or U-joint of some sort at either end to allow for a little ass-symetric rotation. Either way, a plate bracket with a hole in it on the bumper end would be good to hold it square and keep it from jiggling around.
Riley - your version would work good too if the hole for the cross bolt was big enough to handle this slight asymetric rotation, as long as the extension doesn't stick out too far and look like jerry-ville :D.
Have at it men!
:beer:
Rookie2
didn't someone put PVC pipe over the crank and up to the opening in the bumper as a guide? Then you just slide the crank in.... no lining up.
It seemed like a good idea to me!
[quote author=Klunky Chris link=board=2;threadid=15779;start=msg150582#msg150582 date=1083715725]
[/quote]
Another great idea. This one is easy enough even for me. :doh:
Thanks Chris.
Hey but I was concocting half baked ideas where I got to weld stuff together and play with steel!!!!!!!
Thanks a lot Chris!!!
fine then it does sound easier.
Dave
