OEM snorkel template and order checklist (1 Viewer)
asutherland
VA7 HDT
Kamloops, BC
Website
www.forgottenbc.ca
Does anyone have one they could send me? Or a digital copy I could print?
I read the install threads, which are very useful.
I'm ordering these parts (here's my check-list). If you see anything missing, please let me know. :)
17730-66010 (x1), PRECLEANER ASSY, AIR 53.00
53707-60010 (x1), BRACKET SUB-ASSY 18.54
53773-60010 (x1), BRACKET, AIR 6.71
53207-60041 (x1), DUCT SUB-ASSY, COOL 84.71
52853-60010 (x1), BRACKET, COOL AIR 2.63
53208-60010 (x1), DUCT S/A, COOL AIR 45.44
53209-60030 (x1), DUCT SUB ASSY 25.00
52805-60011 (x1), BRACKET SUB ASSY 4.97
96111-10880 (x1), CLAMP, HOSE 5.96
90119-08869 (x2), BOLT, W/WASHER 0.82 x 2
90269-06006 (x4), RIVET 1.10 x 4
90119-06594 (x2), BOLT, W/WASHER 0.57 x 2
I used this with success. I think all but one of the holes was dead on. I placed bolts in snorkel and then with the templet taped to the fender lined up the bolts and marked the one that was off.
ARB Safari Snork Template
when I installed my chicom the template was all wrong. I bolted the bracket to the snorkel then held it up to the fender. I eyeballed everything and marked it with a marker. made adjustments as needed...
He's not installing an ARB or an ARB knockoff. The OEM snorkel template is completely different and a fairly oddly shaped hole.
I have a template somewhere Andrew. I'll look tonight and, if I find it, scan it in tomorrow morning and post it here.
ive never seen one.
Awesome. How do you like it? Any tips or tricks on install? Does the list above look complete? I'm going to order them from Partsouq.
Unfortunately I'm pretty useless on the parts list as I bought mine as a used but never installed kit.
I like the snorkel overall, but you should know going in that it is not waterproof. Install is pretty straightforward but it's tight inside the fender. I used 3m vhb tape instead of drilling into my pillar.
Ping the vendors here such as @beno as they can put a kit together for you. Nothing more frustrating thank missing the last bolt. That’s how I got mine, no way I would try to piece together a kit myself. Also the template has a part number too.
