I did. Sometimes it can be a pain to get the bolts out if they're rusted. Mine wasn't bad at all and I still needed to cut a few of the bolts off. You end up with many small holes and A LOT of stubborn tap under the middle tracks. You can chose to leave them on but if you remove them the double sided tape is hard to come off. There are many different methods to removing it but plan on spending many hours face to face with your rooftop.
To fill the holes I used aluminum tape as a temporary fix. I plan on filling them with putty in the near future. If you plan to put on a new rack, it will cover where the old rack used to be. So there is no rush to do a prefect job right away. Do a search for roof rack removal to see how others did theres and to give you new ideas on how to go about it.
