I am leaning towards an oem or oem style rim with the hub caps. However, my 40 series has a full float rear axle. In that instance would I just order 2 sets of front hubcaps?
That's what I was thinking, just run the fronts on the rear. I doubt the others will clear.But then, no one could see your extremely manly full-floater... Even though hubcaps are cheap, I'd test-fit one to be sure it will clear the hub. You could also run cut-out front caps on the rear, if that's what it takes.
