OEM retractable shoulder belts for a 60????
LOS ANGELES
Website
www.destechservices.com
Guys.... Does this mean I can order the 2nd row seat retractable shoulder belts for my 85fj60? MOT!!!! or anyone... can you chime in? that means I don't have to cut nothing.....
Looks like you have em now, or I might be retarded. Seriously, that looks sweet, very much like the 80 series set up, obviously. Are your existing second row belts worn out?
At the risk of oversimplifying: Take finger. Poke around on pillar for threaded hole. Got one? Order belts. No hole? No belts. Your welcome :)
That's not his ride. He is just posting an example that was posted in another thread. IIRC, that one was being sold in the US, but it was an import (hence his referencing of MOT - as MOT may be able to pick some up in Japan and send them over).
I think they all have the hole, but maybe not. If you do have the hole, before ordering parts, take a look under the head liner to make sure there is a nut insert IN the hole. If not, look at the various posts listed above. Takes a little more work if you don't have the nut, but doable.
The parts list for the FJ60 "General" market (not US), shows three point belts availabe for pretty much all the years (starts in 1982, IIRC). However, there are a lot of different part numbers as the years go along, and there is no distinction which, if any are retractable. They are just referred to as "3 point".
Rob pasted the link to the thread I recently posted. It is the first one.
The problem with the OEM belts is they used the interlocking buckles. Sort of a pain in the rear compared to current models.
My thread shows a way to instal a nut in the pillar with out welding.
Do you have a third row set like in the pics as well?
I have added the rear seat belts to my 85' FJ 60. I found a junked FJ 62 and bought the OEM belts and necessary trim pieces for $100. Installation required using the upper nut already in pilar, drilling a hole, at the base(crazy, though the nut was not there the exact spot to drill is marked in the bottom trim), securing the bottom bolt with fender washers, lock washers and nylon nuts, and then the hard part: cutting approximately 4X4 square opening for the retractors and mounting the retractors. It is tight but doable; even I with my chubby hands was able to get a stubby inside so I could pull the whole thing together with a ratchet. I did the cutting with a small dremel and about ten small, heavy duty cutting wheels. Once this is completed, I added the 62 under window trim pieces designed to neatly secure the belts, and the front trim pieces to cover the reteactors. You have to trim the origin 60 cargo panels to meet neatly with the 62 front trim pieces. It looks tidy, almost OEM to the untrained eye. I wish I was savy enough to post photos, but I'm not. If any one wants to give it a go, PM me.
No third row seat....
The one I'm interested in is the overseas retractable 3 point belt for my US 60. I have the retrofited ones now(see picture below). They are attached to the pillar but do not retract. The place where the retracted part goes changes between 60 & 62's... thats why you cant just put retractable belts from a 62 into a 60 without modifying/fabing something up. My fam. hates the non retractable 3 point belts with a passion. & If I could get a hold of these... at least one.... The family can start using the 60 over the 80 again.....
here is the link
Specter Off-Road-Land Cruiser Parts - 305-66D-3PTC-Rear 3 Point Belt Conversion
It is my understanding that there is NO OEM retracting rear belt for 1988-earlier. There is a non-retracting shoulder belt that clips into a special retracting lap belt.
'89+ bodies have the modified holes and mounting points for the standard retracting belts.
I may be wrong, but I am pretty sure you have to use 80 series or newer belts (if you want TEQ) or aftermarket. Either way have you checked the pillar for threads yet? And you will need to pick a mounting point for the retracting end.
Hmm.... read my previous post.
"I have the retrofited ones now(see picture below). They are attached to the pillar but do not retract."
I already reto'd my 60... it's an 85 FJ60 with the treaded holes already on the pillars... I just ordered the OEM shoulder NON-RETRACTABLE shoulder belts and screwed the bolt. I added the pic from SOR to show where I bought them from. And the picture in the first post is from a 1980 BJ60 SAHARA model. It was on sale and posted here in the forum. And that Is why I am asking.....
Here is the link for the thread
https://forum.ih8mud.com/60-series-wagons/225348-rare-beauty-sale-fl.html
and here is the link for the BJ60 in question for sale on Ebay.
eBay Motors: Toyota : Land Cruiser (item 110260189807 end time Jun-14-08 16:29:41 PDT)
I see, sorry about missing the detail in the earlier post, I was distracted and forgot about that part. But I think the answer is the same.
There seems to be a big difference in the body details between the Sahara HJ deluxe edition and our US basics...
Drill one hole for easy setup or cut a large hole and do the lower profile set up. You can still have the retracting belts. It would be nice to get a hold of the panels that are designed to mask the hardware instead of having to fab them.
I need some help here- I just purchased used 62 retractable seat belts for my 60. There are 2 trim pieces included. It looks like I'm going to have to trim some of the interior panels to make it fit. I was hoping to not have to do this.
Can someone post pictures of the interior of your 62 showing the rear trim around the retractable seat belt?
Searching all the old threads, I haven't seen a picture of a clean, factory looking install with the retractable belts. Cruiserparts sells the kit, but they don't have pictures on their web site to show what it includes.
Here's what I bought on Ebay:
eBay Motors: TOYOTA LAND CRUISER 89 FJ62 REAR SEAT BELTS BROWN NICE (item 320322035173 end time Dec-07-08 16:43:41 PST)
I need the wheel well cover and side panels to complete my retractable seat belt conversion. I really didn't think I'd have to hack up my existing interior panels to do the conversion.
Does anyone know what the cruiserparts conversion kit includes? At this part, I'd even buy a really inexpensive brown interior FJ62 to scavenge parts off of (like the seat back with head rests).
Hank 14, The panels have to be trimmed back as I indicated in my post, A utility knife with a sharp blade yields great results. When cutting, cut at a bevel to insure a tight fit. If you are really ambitious, you can search out the right color caulking and lay a bead at the joint, following the contour of where the panel meets the wheel well. The attachment buttons line up. As far as the 62 panels, the passenger side might fit, but the driver's side is a three section panel/compartment cover, and I'm not certain the attachment clips/buttons are in the same place. I'd show you, but I am not tech savy enough to send photos. If this remains a big issue with you, PM me, and I'll find a Gotham Club member who can send photos along to you.
