Not specifically I don't think. I'm one to just slobber oil on everything then run it up and down holding it at weird angles to hopefully get oil to the gears and threads inside.The telescoping sections are greased, the clicking is coming from inside. I'll look it over but is there an oiling hole anywhere?
Now, now, that screw together handle wasn't designed by Satan, it was designed by a highly paid automotive engineer who never once had to actually use it. Truth be told It was probably designed by the same engineer who though it was a good idea to put that inaccessible bolt on the back of the block that holds that metal tube in place that feeds coolant the PHH.That janky screw together handle was designed by Satan himself
I do remember at some point in time I twisted one the square part extensions. Don't recall what I was doing and didnt regard the actual jack. Want to say it was remove the seized spare tire carrier. Anyway the 3 piece extension set up alway felt a little janky as you put.Might have just been the janky handle assembly and how it fit. Using the drill it went up and down with a load without issue.
