I heard the Fiamm horns fit well, but i have no experience with them. I think Camry horns have been used as well and are much louder.
The Fiamm horns fit quite nicely and were easy to install. Good sound without being insanely loud. Just a good American-sounding horn.
*Help*The Fiamm horns fit quite nicely and were easy to install. Good sound without being insanely loud. Just a good American-sounding horn.
Howdy! Make sure that you did not just run the drounds to the radiator support bracket that the horns bolt on to. It is not a good ground. Run them to the same bolts in the fender that the headlights ground to. Worked much better for me. JohnI re did the grounds from the rear of the horn to the frame and still nothing. I think it's a combination of bad ground/poor factory connectors.
What size are the bolts holding on the horn bracket to the frame? I think I need new bolts as mine aren't snugging up good enough. I think they're 12mm but I don't know the rest.
I'm also going to cut off the factory connectors and try normal female connectors and see if that works.
I installed the Fiamms (sp?) and they are alright. You need to get one "high tone" and one "low tone". They will last about 3.5 years and then they tend to **** out completely. They are not "highway blasters" by any means but they are alot louder than the stock setup. For the fellow who's horn was working and then wasn't working it is almost definitely a bad ground somewhere. You need to make totally sure that the ground is good. HTH.
So if not Fiamms, then what would be a better choice? I was going to get Fiamms, but if there's something easier and still simple to hook up, then that'd be cool... Fiamms seem to be a very popular choice.
*Help*
I pulled out the factory horns and bolted 2 of these in their place. I connected them to the factory harness and also ran the supplied wire from the other connector to the rear of the horn as instructed. They worked at first but then nothing.
I heard the factory relay clicking when the horn was pushed so I replaced it and it didn't fix the problem. The 15a fuse is also intact.
Please help.
