Disclaimer: I know new floormats are still available, and I know mine is still far from restored, but I'm cheap and this is good enough for me, so maybe someone will find it valuable.
Anyway, my floormat, as you can see, had many rips from the corners/stress points, was worn through on the drivers side, and had lost all of its grey coloration.
I used grey PVC cement which bonds with the mat material to apply patches and reinforcement to the back of the mat. I used grey upholstery vinyl with fabric backing for the patches. To finish I sealed split areas on the front of the mat with my PVC cement, then painted with a good plastic primer, and finally grey enamel which matches the rest of my mats.
Note that its important to clamp the patches well, I used pieces of wood and bar clamps to clamp for 2 hours.
. The only reason to buy a new OEM one is if you have done a frame-off or you have a VERY clean original.
