Not extremely technical but I wanted to see if anycould give me some hints or suggest a possible aftermarket item to solve this issue.
I recently noticed on one of my rear bumpstops, that the rubber portion was good. I got a clean used rear bumpstop and proceeded to upbolt the old one and put the new one in.
When removing the bolts, both heads busted right off. So now im left with no bumpstop at all. Yes, i tried drilling a small hold in the studs and using an easy out but no luck, its an extremely tight spot to work in and I cant seem to get a good bite.
My only real concern is bottoming out the shock, if no one thinks i'll bottom out, then i'll just leave it for now.
Thanks.
BTW, i'm running heavy load springs, if it matters.
Thanks.
