OEM AC Nippon Denso Radiator Question 1979 FJ40
Is the AC radiator a 4 core radiator but oversized?
Yes.
The radiator frame that the radiator bolts to is wider, the shroud is wider, the engine mount on the passenger front is different, the battery frame/support is different, the alternator bracket is different.....
possibly an add electric fan that does not alter the truck permanently.
Whats your idea on that?.... being space so is limited in that area..... If this was mine I'd just go with a standard 4 row radiator simply to avoid the need for the larger shroud and core support..... Now that I think about it, I wouldn't do this install at all.... that factory a/c wasn't very efficient to start with, plus its Fugly!..... The Vintage system has much better air distribution and has more eye appeal....
1. thickness 4
2. length 21 1/2
3. and the height is around 22 3/8. That one was hard to do.
I have heard that there is a lot more to it as well, other than a radiator. I know that AC was an option on a 79-84 but I have never seen a 79 with factory AC. Maybe someone with a 79 will let us know. As far as vintage air, they work great. Vintage will freeze your ass off. Mine is factory and blows ice cold on a 99 degree day in the sun. I prefer factory because I am a purist but really can't afford to be. Hope this helps.
Sparkplug- thanks for the help. I really appreciate it. What you said about OEM AC is spot on. I would rather have a 100% factory truck with mediocre AC. If I ever had to unload it (heaven forbid) I would expect a premium with OEM ND AC over Vintage aftermarket stuff. I know there are alot who don't agree. Just my .02C
The idea with the electric fan would be add another source of cooling that could keep the truck in the right range of temperature even on a hot day under load.
Thanks
Aaron
Glad I could help. Any other pics I can take or measurements let me know. I was talking to Marve over at SOR today about getting a spare temp and fan speed control. I hear if they break, they can't be fixed. Don't ask me why, I am very challenged. He didn't have any. I have been stock piling spare parts for my 40 because it is an odd ball year. I even have spare floor mats just sitting in my garage waiting as a second string so to speak. Get them while you can. I am only 34 and plan on driving my 40 until the day I die. My only hope is that Toyota will wise up and truly bring back the 40 one day.:cheers:
Also, my AC is not mediocre, it works great. The only problem is that when you first get in the rig is hot and the vents don't blast you with cold air. Just give it time, kinda like our 0 to 60.:banana:
The idea with the electric fan would be add another source of cooling that could keep the truck in the right range of temperature even on a hot day under load. (quote)
I don't think mine has the electric fan and the engine temp gauge never gets anywhere near half way on a 97 degree day on Louisiana. I don't think you need it(could be wrong). Also my father has a 83 fj-40 and his is super cold. He has middle vents where mine only has side vents. My passengers always complain at first(before the cabin cools off) that the vents don't point directly at them. You may want to look into that. This is a pic of mine. Sorry, I don't have a pics of my dads, but on his in the middle has vents as well. If you want a pic, let me know and I can get it. The pic is a little strange because it is in my garage and I had to use a flashlight for extra lighting.
sparkplug....my unit has more vents, all the way across the front. 1980 FJ
riddler...not certain but, I think the radiator needs to be wider to clear the lower hose past the a/c belt. I ordered the lower hose from cdan 2 years ago and it was special order.
did you put the 3 row balancer on?
I think mine is just a pop out plate in the middle. (not sure) so it could be all the way across if I had the vents. Yours is the first 80 that I have heard of that has factory AC. Still waiting to hear from someone that has a 79 with factory AC. I know it was an option. How does yours work in the summer?
What is a 3 row balancer? Also, I hear that there is a special diaphragm for the carb at idle when the AC is on. It was not standard on all 79-84 with AC but some had it. I don't know if mine has this either. My 84-60 has AC and it looks exactly the same. Sorry, I am Land Cruiser challenged.:meh:
spark plug, your louvre is the updated later style. it has the center vent, I bought three brand new louvres a few years ago like yours. you will need to try to push it up or down a bit and it will pop off its detent and fold down to a full louvre. it kinda rotates up(or down, cant rember) to where the bottom is what you are seeing, and it justs needs to be rotated.
-Brett
-Brett
Thanks Brett. I pushed it down and now my passengers will have to complain about something else. Very cool. I would have never known.:doh:
maybe a better term is harmonic balancer?? off the crank. you use 3 belts to drive all parts, alt, smog,water pump, a/c. non a/c motors just had a 2 groove pulley
I thought my rig was kinda rare when I picked it up, 1980 with PS A/C. Used to have a 79 that just had PS.
