I have an 82 with 135k on the 2f, recently the idle went low and to get home from work had to run with the choke pulled out slightly to keep from stalling. I changed the fuel pump two months ago and the fuel filter, spark plugs and distributor cap and rotor last week end. That has not helped. In looking at it this afternoon I found some loose bolts on the intake/ exhaust manifold, tightened those to no effect. What is odd is when I pull the cap from the vacuum tube at the base of the carb the idle goes up and there is gas in the cap. In the past if that cap leaked the idle dropped or it stalled. It acts like a vacuum leak, sort of, but I can't find one ( spraying starting fluid at suspect areas) . What the heck?
