G'day, got a odd coolant leak on my 13BT which I am unsure of where it is coming from, first pic is of the puddle on the ground and the second of the drip rail around the sump, which is the only place I can see wet coolant. I have pressure tested both cooling systems and they hold pressure.
I have spotted this leak twice now, only after the car has been sitting for some time, ie its been sitting over a month now and just noticed the leak yesterday. Same the previous time, sitting for a extended time when I noticed the leak. Any ideas? Nothing on the bash plate under the radiator and the coolant hoses are tight and no evidence of leaks, I have also tightened the water pump bolts, were not loose. Is there something behind the timing case or pump which could leak? Everything looks dry above the drip rail.
