That's good info, and similar to my experience. Mine felt nice, without much increased breakout force at 30lb/ft. They still turned fairly easily at 50 lb/ft, but I played with them a few turns and then backed torque off all the way, and then back up to 30 before securing it.Spinning the hub by hand didn't feel much different than it did at 15 ft*lbf or 25 ft*lbf inner nut torque. It certainly spun without feeling like the bearings were bound up, but with the grease in there and the new seals its a little hard to feel small changes the bearing preload is making. Once you are to the point where the bearings are dragging you are way too tight. I'd guess that's in the 40-50ft*lbf type range. Probably still work, just at a reduced life.
