OBD II connector pinout scheme Reset of VSC ABS sensor fault
norway
Hey
anyone have the pinout schema for the OBD connector port?
im gonn manually reset VSC ABS sensor flashing lights in the dash.
The other day my ABS, VSC lights was flashing. I was washing the car with the engine on and its just started to flash.
Maybe bacause i was doing high pressure washing on the calipesr in front(sensor??)
i did try to check the tank filling caps and other tips, did not work
Hey
This is a shot in the dark, but you might check that the ABS wires did not get damaged from the pressure washer. It sounds like from some other threads that these wires can be easily damaged when working on the suspension.
Will check it. When im like turning the steering wheel ans doing a low speed turn, it seems like the brakes is coming on, liek its really slow
Hey
Any resolution here?
