- Location
- United States
I'm selling a 1991-1992 NV4500 five speed transmission as-is. I don't know the mileage as I did not pull it from the donor truck. This is a great five-speed truck transmission for engine SBC engine conversion because it will fit with a little work, the granny gear and overdrive. Here is a link to info on it: NV4500 Transmission | Advance Adapters. Its out of a Dodge truck as it has the 23 tooth spline rear output shaft.
1st Gear Ratio: 5.61
2nd Gear Ratio: 3.04
3rd Gear Ratio: 1.67
4th Gear Ratio: 1.00
5th Gear Ratio: 0.73
Reverse Gear Ratio: 5.04
I've gone in a different direction with my project and want it gone, hence the low price. These normally go $500 and up.
The transmission is in northwest WI, specifically Prairie Farm, zip code 54762. I can be reached at (nine five 1) Two hundred and seven, 28Oeight if you have any questions on it. To view it, you'll have to call my father, Steve, in WI at (Seven hundred fifteen) 4 fifty-five- 16 twenty nine.
