I didnt hear anything. Is it on this pic? Clutch cylinder is in right corner.
Ah. So something is supposed to be here?No. Pan down and to the right a little. It's a large black component on the inboard side of the vent louvres.
Cool ... not sure if that's the problem, but either way now I just need to figure out part number and if still out there somewhere. Thx !Yep, the carb cooling fan.
Any chance to get a pic that shows that tag with part number there?Yep, the carb cooling fan.
Copy ... thx.You'll have to buy one used, but I'll look up the number tomorrow.
Stock ... I thinkDo you still have the stock cast iron exhaust manifold on there, or does it have headers?
Yes ... stock radiator ... had inspected by radiator shop a few months ago and was okay ... temp seems normal (radiator shows 185 w/ laser thermo; watch it flow thru Gano when hits 190) ... uhh, he sheepishly says IDK timing.If the engine is running hot, that will increase the percolation/evaporation problem.
Is the radiator stock?
What is the timing set at?
Inspected 40 year old radiator= buy a new radiator.
And check the timing.
I’m not guaranteeing it will solve your problems, but it will help.
