While I have not tried or been able to figure out why, I have noticed after installing airbags (from airbag man which is firestone bags with a kevlar sleeve) and keeping them at the recommend low setting of 5 to 8 psi when not towing our travel trailer, that the car is slightly up on the rear (maybe 1/2 inch), however the nose diving under breaking is noticeable less, which I quite like.
As indicated, what is happening to the suspension is not very clear to me;
- Maybe the KDSS is put under extra pressure which is perhaps itself not good and is not intuitive as it is supposed to control sway
- Or the rear does not come up as much under breaking, which is not intuitive either as the airbags really prevent compression but probably do little when the springs are extended
- Or the front gets more pre compressed which I do not really see from the stance of the vehicle
- Or some combination of the above...
Maybe somebody good at suspension geometry and behaviour and understanding of the LC200 specifics can shine some light on this. I do know the nose diving is noticeable less after this mod.
Thanks in advance!
