Do these units put off a lot of heat inside the vehicle?
Note: This feature currently requires accessing the site using the built-in Safari browser.
FirstToy said:not at all and you can barely hear it, if at all.
Boston Mangler said:I got the transit bag for mine and it is even quiter now!
Dunbar said:I leave it set on 2 and the thermometor reads about 40. I try to keep at least a dozen beers in it for improved efficency.
Dunbar
Boston Mangler said:weird, i put my 45qt on 2 and it freezes everything in it and my engel thermometer reads 29-30 degs
reffug said:I got the 63 and at 2 it will definately freeze chit.....
NorCalDoug said:Mebbe it's a norcold thing? dunno. could be his is older.
do you keep that 63q running all the time?
reffug said:Mine's an ARB although I thought they were all the same.
If I'm using it yes I pretty much run it all the time.
And don't call me buttercup...............![]()
CTapia said:I had a hard time justifying the $100+ for the transit bag, Is it worth it?
NorCalDoug said:I asked if your ran all the time because I heard from a not-so-reliable source that the big one like yours draws a significantly higher amount of power from the battery than the 40-something quart sized ones (like mine).
Are you dual-battery or cross-your-fingers while carrying jumper cables?
