noob need help steering & suspension Q
HUNTSVEGAS AL.
well this day started out with getting a front alignment for my 94 4cyl 4x4 reg. cab then being told i couldnt because of needing a new idler arm & pit arm ... so went home done some google'n bought a mcquary-norris fa 5040 idler arm & sodri product bushing kit... well while I was looking there I also bought the 1.5" front balljoint spacers
so now i got 2 questions
1. what brand pitman arm should I purchase ? want to do it right the first time !
2. rear is sagging already going to look even worse whith the front lifted 1.5" so whats my options for lifting the rear easist to cheapist ?
Thank you in advance !
OME Medium load leaf springs unless you want to carry 400lbs or more normally, then get the heavies. Medium dutys will get you 1.5" lift and heavy dutys will get you 2".
If it is sagging, then the current ones are shot.
