- Thread starter
- #21
It's called 'broadcast radio'.What's AM/FM?
so I am assuming this manual antenna is a direct bolt in for US spec 80's?
I believe so.
Same part number was used in LHD and RHD models for the general market
looks like you ordered the one with "30" at the end instead of "20". I ordered the "20" hoping it will fit my daughters 80
thx, I hope so, ordered one last night with the 60020 at the ending hoping that is the right one? ordered one for my daughters 80, would rather have a manual antenna anyhow and remove the power switchI believe so.
.............would rather have a manual antenna anyhow and remove the power switch
go with a cb antenna, you can buy a splitter to use the cb antenna for both fm and cb. I think I am running the bracket from gamviti. @TRAIL TAILOR makes a slick antenna mount for the stock 80 hole.For my 80, I want neither a retracting power antenna or a manual retracting one. I want one that is fixed (ie. does not retract) and not massiely long. An option (though very woke) would be a sharkfin antenna as my 80 already has an old original cellphone antenna base on the roof near the front so I could re-use that hole. But maybe a sharkfin would require a different mounting setup. Even a very short AM/FM non-sharkfin would be usable on the roof in that spot. I was just wanting to make use of the hole in the fender panel when I replace the one that's got the maaaaasive rust hole. but if need be that can just be left with the 'chinesium' antenna base (it's been cut off from it's cable).
Can't seem to find anything on that company's website.go with a cb antenna, you can buy a splitter to use the cb antenna for both fm and cb. I think I am running the bracket from gamviti. @TRAIL TAILOR makes a slick antenna mount for the stock 80 hole.
yeah just contact Jason, he might still be making them. Use a firestik small antenna, run one on my truck and it works great paired with a firestik spring. If you don't want to use the stock hole you can just get a bracket from gamvitiCan't seem to find anything on that company's website.
Are they direct swap? I’m thinking about trying out the Ronin Factory stubby antenna since mine just snapped and I don’t want another long antenna. I don’t even have a radio in at the moment.You can use one off of a Tundra or a Tacoma. Those are fixed flexy style non-moveable antennas that keep things OEM.
