Non ABS master cylinder ? (1 Viewer)
Washington
What info can anyone give on the Aisin 47201-60540 brake master cylinder? I have a US spec ‘94 w/ ABS and looking to delete ABS and go manual proportioning rather than LSPV. In searching I have seen potential for that MC to have a drum brake residual valve and others that say it will work with 4 discs like I have and has no residual. I’ve got a new 60540 in hand and visual differences are just the locations of the fittings which shouldn’t matter as I will be rerouting those anyway.
Thanks for the time!
That MC is spec’d for 93-94 without ABS. Just use a proportioning valve at the MC and it’ll work fine if the booster isn’t crap.
A proportioning valve may not be needed from what I've read. Maybe run without it and see?
