g-man
- Thread starter
- #21
I'm going to try and put a spacer in my original Toyota pulley and use it. Ordered a couple steel bushings. 5/8 ID x 3/4 OD. My thought is to try and use it as a spacer. I will drill out the pulley to 3/4 inch. Which is just a hair bigger than it is now 19mm? Cut a keyway into the bushing and then press it into the pulley. Then weld the bushing to the pulley on the side of the pulley.
Another way I could try and NOT drill with 3/4 inch drill, cut a keyway slot in the bushing first (while it's easy to access) then press it into the pulley. Like a slot that goes completely through the wall of the bushing.
. I know this will collapse it a bit. Then weld it, then file out the slot if necessary to fit the key. Also this way I will have to drill out the 5/8 ID again after it is in place b/c it will probably shorten. I know the bushing will move and the Inside diameter get smaller.
