Hi All,
Back in October my power steering belt started to whine. I figured this was due to the colder weather and the fact the belt was NOT OEM and it was also a cogged belt.
I got a new OEM belt from CDan (which is also cogged) installed it started the truck drove around the block and the noise was back. The belt was pretty loose so I increased the tension and then decreased it some more. The noise will not go away regardless of tension.
However pouring water or spraying belt dressing on the belt makes the noise go away temporarily.
1) Could it be a pulley?
2) Any advice would be appreciated. I have read that the 1fz sometimes has issues with the tensioner pulley, but am unsure if that is the same for the 3FE.
Thanks in advance.
HEFE
Thanks in advance.
HEFE
