Noisy heatercore
Bend, OR
Website
elvinsmith.com
Hi,
I noticed something odd in my 60 yesterday and was curious if it was common. When I hit the gas I can hear water "noises" in my heatercore. It is kind of like a gurguly surging sound. I know it is fro mthe waterpump maaking more pressure but is it common to hear it? There isn't any wet carpet or a leak in the coolant system to my knowledge but I have only had it for a month.
thanks,
E
I think its from the heater control valve. When the system cools off it sucks in some air which gets circulated through the heater core when you start up. Yea, I know the system is supposed to be under pressure - so how does the air get sucked in? I don't know, but I still think a new heater control valve will eliminate the gurgle.
You have air in the system. Most likely your radiator cap is faulty so replace that first before you replace the heater valve which is a medium pia.
Posidon,
My advise is the same as Cruiserdrew with the additional suggestion that after replacing the radiator cap that you park the truck with the front as uphill as possible for the next few days with the heater on full for the last few minutes of driving each day and left on full overnight. That should bleed out the air as the air will naturally gravitate to the highest point of the system and as long as the heater is on full the air should come out.
p.s. Are any of those parts rigs '55's?
