Noise from Center Console Area. With Video
Bizarre. Almost like a pump trying to prime.
Can you feel any vibrations on surrounding panels? That might give you an indication of what to start pulling off, where to look. What if you go under the car in the same area, do you still hear the same noise, feel vibrations, etc?
No Vibrations, I have flushed tranny, Changed AHC, Everything works properly. It has me stumped as well.
Check the fan to your amp under the driver seat, if you have the Mark Levinson system
Or one of the fans in the sides of the nav unit within the dash.
Thank you. I beleive you are correct. Tried to blow it out although the noise is still coming. Any suggestions on a fix?
