Need some help here. A couple of months ago I developed a strange rattling/whirling sound coming from what I thought was the engine bay. I pulled the serpentine belt off and checked all of the pulleys. The idler pulley seemed loose and made a very slight noise when I spun it. Everything else seemed fine. The power steering pulley/shaft did have some back and forth play on the shaft, but I think it was normal. I swapped out the idler pulley and belt with new OEM ones. The problem is still there.
Here's where I'm at right now:
The sound only happens when the engine/drive train is cold
The sound appears to be loudest under the transmission pan
I know it's not the typical TC cold weather whirl, I'm familiar with that.
It's not the header as I have DT headers.
I did a mobil 1 ATF drain/refill last week (after the problem started)
Any suggestions? I'm at a loss.
