I went to pull my 80 into my garage a few hours ago and it didn't start, some things were clicking when I turned the key, all lights on the dash were normal, but the starter isn't doing anything.
First off, I need to be clear that I did convert this thing to 12V start a few years ago, it hasn't given me a single issue since the conversion.
I have independently verified that the starter is working (by bypassing the starter relay with a jumper).
Also the Starter relay is clicking when the key is turned, and the contacts read 0.0 ohms when the relay is energized.
I have found that I do not have proper voltage at the spot I circled in Red. Interestingly, I do read 12.2 volts (but not the 12.7 that I have at the battery) But this voltage disappears as soon as any load is present. This part has me stumped, but I think that part of the voltage regulator circuit is also tied to this white wire, so maybe that's were the 12.2 volts is coming from.
As Mentioned above, If I use a jumper to put 12v straight to the B-R wire the starter jumps to life. However if I unplug the relay and place a jumper from the white wire to the B-R wire, nothing happens.
The fuseable link seems fine, and everything that feeds off of it is working as it should.
As far as I can tell, the green highlighted part is relevant to my JDM cruiser, and I do not have the "FL ST 0.5g" link.
I need to find the 2 places circled in yellow so I can try to narrow down where the problem is.
